Garmin HR monitor not Connecting to Edge530
I have had my unit for nearly 10 months and only very recently has been playing with not connecting to the Edge unit.  I have removed the sensor few times and reconnected again with no luck.  I know it's not the HR monitor (I have Edge530 Bundle) as it connects up with my Wahoo kickr no issue and reads fine.  Please help.
  • The reason I said what I did is because an Edge device does not really differentiate in what sensor it is receiving info from. If an Edge can receive any ANT+ signal, then it should be receiving all, which is why I would say the HRM is at all fault.
    However, if you were pairing as a bluetooth sensor, removing this pairing and pairing again using ANT+ would be a good troubleshooting step.
  • Thank you.  I have now connected via Ant+.  Will update in next couple days.
