I recently purchased a 530 to replace my old trusty 520. I set it up according to the instructions. I am reasonably tech savvy.
Apart from that I have made no changes. I have an indoor trainer which is a Tacx Neo and I use the same bike on and off the trainer. My roadbike has a duotrap cadence meter which has worked fine for many years.
With my old 520 my cadence readings were fine no matter when I was on the road or on my indoor trainer and I don’t recall any challenges setting it up.
With my new 530 my cadence readings are still fine out on the road. However, on my indoor trainer my cadence readings start ok but quickly overshoot to nearly double what they should be (I have been riding for 5 years using sensors so I am sure about this). My cadence then continues to spike and revert to normal levels and then spike and revert to normal levels. Also it seems to be that towards the end of the ride or when I am pushing for a higher power output that the cadence reading settles down to something more reasonable. After trawling through this forum and others I have concluded that this issue is probably the Tacx cadence itself which is a calculated number. I know I don’t have a smooth pedal stroke due to an old knee injury. I also checked that it’s the Tacx cadence output by using the Tacx Utility where the readout exactly corresponds with my cadence readout on my 530.
I have updated the Tacx firmware to current.
After much fiddling about changing sensors connections on my 530 I still cannot isolate to reading the cadence from my duotrap but the power from my Tacx. So as far as I can tell I cannot solve this problem. The only way not to have the Tacx cadence output showing on my 530 screen during my ride is to disconnect my Tacx indoor sensors entirely from the 530 device which would mean I also dont get the power output which defeats the purpose of having my Tacx for indoor training in the first place.
So my ask is, just in case I have missed it somewhere, ...can anyone tell me how I can solve this?
