I´m using a Fenix 6 and a Edge 530 to ride. I tested some solutions:
- use each one individually, the problem with this solution is that they generate two activities that hinder training statistics.
- use the Edge as an extended screen (the menu is difficult to access and the connection is not the easiest, it is often stuck waiting for the clock) but after it works it is interesting but the map view on the Edge is lost.
any other solution?
