I would like to send a map file to my Edge 530 without a USB connection. Is it possible?
You will not be able to load a new map or a map update wirelessly, either with BT of WiFi. This has to be done with a usb connection.
If you meant GPX file, you can:
Load it into the Garmin Connect on your phone, in the UI of the GPX file loading, give it a name and click on send to device.
Choose your Edge device and then perform sync…
Choose your Edge device and then perform sync between your phone and Edge via BT.
If you meant the map itself, then no.
Loading of gpx file worked. Thanks
If you create the route in ridewithgps you can download routes using the ridewithgps Connect IQ App.
See here: https://apps.garmin.com/en-US/apps/773bf1d8-9f65-4e50-8517-e13ffd064d54
