Edge 530 problem with many jumps on the road
Ahoj ,
Mám Garmin Edge 530 a po aktualizaci na verzi softwaru 7.1 a testovací jízdu na outdoorové aktivitě na kole. Mám problém s mnoha skoky, pokud jsem neskočil.
zde můžete navštívit moji aktivitu. activity
Nechápu, proč to dělá. Možná chyba v softwaru na hraně 530.
    is this jungle jim ? What happened to your english ?
  • Hi ,
    I have a Garmin Edge 530 and after updating to software version 7.1 and a test ride on an outdoor cycling activity. I have a problem with many jumps if I didn't jump.
    you can visit my activity here. activity
    I don't understand why he does it. Possible software error on edge 530.
    A big enough bump will trigger the jump detector.  It is based on accelerometer data I think.  You can turn off the jump stuff if you want.  It is in the MTB/CX section of the profile settings.  That stuff isn't very useful when not mountain biking.
  • the OP is Czech going by what they wrote.  English isn't their native language.
  • I don't want to turn it off, with software 7.00 everything worked as it should. It's causing problems now. I apologize for Czech, I didn't notice any mistakes.
