Hello all,
I have a Garmin 530 that I use for cycling and a forerunner 45 that I use for running, is there a way in the calendar to associate each schedule exercise to a device?
thank you
You will be able to individually send workouts to a specific device, either through Garmin Connect or with a .FIT file, but you will not be able to select part of a calendar for each device.
Only the workouts that are supported by a device will show up from your calendar. For example, if you happened to have a swimming workout scheduled, this would not display on an Edge since it does not support that activity type.
