Cadence sensor 2 irregular cadence
I have 530 with cadence sensor two and i find that every few minutes i get a reduction in the reported cadence for around 5-10 seconds, e.g. I am at a constant 90 RPM and it reports ~65 rpm, and then returns to normal. It nearly always sits on 65 or 66rpm, its not a drop out, both my powermeter (powerpod) and 530 record the same cadence. This happens whether i have the powermeter present or not, or whether I am solo or in a bunch. Only other sensor is speed sensor 2.
Any idea? I was thinking it might be the choice of connection Ant/BT, but beyond that I have no ideas?
  • Try a new battery.  How are you connecting - ANT+ or BT?  Try both of them and see if the issue is resolved using one particular connection.
  • Do you see this same drop out or reduction in any of your other sensors? Also, what bike is this mounted on/what is the crank arm length?
    I would agree with the suggestions of trying a new battery and then changing your connection to whichever standard you are currently not using. (my personal preference is to use ANT+ whenver possible)
    0 Former Member in reply to Garmin-Blake
    No other sensors are fine. On 170mm cranks. It's mounts on a de Rosa merak evolution
