wifi
How do I synchronize activities via Wi-Fi without using the smartphone?
    I finish an activity I get home the garmin connects to the Wi-Fi but it doesn't sync and I can't find any option on the device to sync it via Wi-Fi
  • As long as you have successfully added your network, the activity should automatically upload when you are within range of that network. If you have a bluetooth connection active, your activity will upload through Garmin Connect Mobile first.
    0 Former Member in reply to Garmin-Blake
    I have succesfully added my network and dont work. It could be better if I can syn now with and new option like fenix 6s, because dont do auto
  • You will not be able to upload an activity from your 530 using a fenix device. I apologize if that's not what you were saying.
    If youhave the option to manually upload a ride by going into the main menu, History > Rides > open activity > Upload Ride.
    If this still fails, you will need to remove and then re-add this wifi network, or check for compatibility. You can find more wifi troubleshooting at the link here.
    menu history rides open activity and not appear UPLOAD FILE
    0 Former Member in reply to Former Member
    Iam connected by wifi., appear the icon WIFI full in the main menu
