Hi All,
I have an issue concerning incorrect (too high) power data display from trainer to bike computer.
My trainer is: Elite Turbo Roteo Smart B+ with Misuro sensor.
My bike computer is: Garmin Edge 530
I connect trainer to bike computer using 2 sensors: 1. Cadence/Speed (with manual wheel circumference setting) and 2. Power (both come from trainer sensor)
I have tested 3 use cases using similar sample conditions (spd. 17km/h, cad. 70, HR: 120) and I kept getting the following power output readings:
Case 1: trainer with myEtraining software:
Power: +/-100W
Case 2: trainer with Garmin Edge 530:
Power: +/-425W
Case 3: trainer with Garmin V3 dual-side power meter:
Power: +/-100 W
(presenting data to Garmin Edge 530 to cross-check if trainer power output values are comparable)
What I can see from the exercise is that:
- the trainer is calibrated correctly as the sensor is giving power output comparable with power metered pedals
- the trainer is capable of sending correct power output as it shows correct value in myEtraining app
- Speed, Cadence and HR values are accurate (comparable) across all 3 scenarios and they are presented consistently in both myEtraining app and Garmin Edge 530 device
- there appears to be some data glitch between Elite and Garmin causing power to be more than 4 times too high (unless I have done sth incorrectly)
If anyone else had similar issue, I appreciate help and guidance on how to get it fixed pls.
I am going to report the issue to both Elite ad Garmin. I will update the forum in case I get to hear from them on any viable solution.
Many thanks.
Zivkov
