Hi,
I realize that this topic comes up a couple of times in this forum but I could not find an answer about how to proceed in my case.
I'm seeing plenty of power meter reading dropouts from my Garmin Vector 3 (dual sided) to my Garmin Edge 530. About once every minute for a couple of seconds.
Software is up-to-date on all devices (Edge 530: 7.00; Vector 3: 3.80).
It happens both in ANT+ and in BLE mode.
It's *not* the dreaded Vector 3 problem because my fenix 3 records the power values continuously just fine.
Here's an example of a fit file with power dropouts on the Edge 530:
https://connect.garmin.com/modern/activity/5867343019
I can provide the corresponding power values from the home trainer to show that the power is continuously on, i.e. there should not be any interruptions in power.
Here's a short stretch of data recorded with the fenix 3 to show that the problem is not coming from the pedals:
https://connect.garmin.com/modern/activity/5867993004
What's the next step to get this problem sorted?
Thank you for your help.
Christoph
