Problems after 7.00 update
I'm using Edge 530 to control resistance on my Tacx Neo 2T in following workout mode, and eveything up until this update worked flowleslly. After update which went without a glitch, Edge could't find my trainer resitance control, but did automatically connect to Tacx's speed, cadence & power sensors. It needed a restart to find all the connections, so I started my workout. In about 15 min of training resistance on Tacx went nuts, up an down, so I had to stop, I tryed to trickle with settings. After restart everything went well, until I finished workout, and tryed to save my ride. Upon pressing save ride option, Edge opened new window with paused 6 min ride with zero kilometers on it? I saved this ride too, and after that I found myself with two saved rides. The actual one of 1hour20mins, and ghost one of 6mins and 0 kilometers.
  This was my first ride after update, so I don't know if this will be reoccuring issue. I've played with settings on Edge and everything seems normal.
Anyone with similar expirience?
  • I'm sorry to hear about that issue. That's for sure an odd one and nothing in the update should have caused this.
    I would recommend removing your trainer as a sensor, then performing a hard reset by turning the device on then holding in the power button for up to 15 seconds until the device shuts down. Then you'll need to power it back on and pair the Neo under the Trainer settings on the Edge.
    since the last update I have also lost some functionality. I have lost the option to choose a language ,I just can choose a few languages and I don't  understand them, so I appreciate the solution to the problem.
    0 Former Member in reply to Former Member
    Hi,
      You can try a solution with hard reset provided by Blake. It helped me.
    Br,
    Dalibor
