Has anyone used their 530 in Indoor Training mode coupled to an ANT+ / Bluetooth FE-C Smart Trainer? If so, some questions:
- How well has that worked when you simulate a Course or a previous ride you've got on the 530?
- Can you setup and see more pages on the 530 beyond just the elevation profile and Virtual Partner pages? i.e. can you create a page with speed, distance, cadence, etc.
- Does it do a good sending slope information over FE-C to the Smart Trainer to instruct it to alter resistance and simulate the grade?
- If the answer to question 2 above is Yes, does the Grade field show the simulated grade or just show 0 because the GPS and altimeter are not seeing any grade change?
- Is this a viable use model to simply do an indoor simulated ride of a ride you've done outdoors (winter is here, more riding going indoors)?
- Any thoughts or suggestions you have?
Thanks for your thoughts !
