Edge 530 & Tack Neo // Resistance dropping to 0 every few minutes
Hi Garmin/Tacx,
Yesterday I started my indoor season with TrainingPeaks HR structured workout. As it was HR based (syned with TrainingPeaks) and I used MTB on Neo then I had to increase resistance or set incline up, that my last gear was not too easy. So I did set it to 3% incline and started by HR structured workout with Garmin. Very strange was that after a few minutues or especialy when next step in workout started - resistance/incline droped to 0 and i had no resistance to work with.
I disconected Neo from Garmin "Trainer" sensors and left only as Power & Speed/Cadence sensor, but the same issue occurs.
So why this happens if I use Garmin as my Workout master, but NEO does not stick to fixed incline/resistance set by Garmin 530?
Acctually i moved even futher. As it was HR based training and i just needed "a dumb" trainer, I used Tacx Neo app where I can also set some Incline% and ride. But when in Garmin next workout step starts - it again overrides app Incline and again is set to 0.
What do I do wrong and what is the best way if I want to fix Incline/Resistance for my TrainingPeaks HR based workouts?
Hope to hear you soon!
BR,
Māris
P.S.
Everything is OK with Power based workouts, but sometimes coach adds HR bases training and then its a mess.
