I read a lot if issues with the new sw version. Which one is better 5.5 or 6.2? Is it possible to downgrade from 6.2 to 5.5?
FW 6.2 works fine for me. This is what I have been using on a regular basis, without issues
- Standard routing & recording
- training workouts
- training status, training load, vo2max,.....
- connect powermeter and HR sensor
- Strava live segments when not routing
The only use case relevant for me I still need to test Is Strava live segments when routing
Firmware version 6.2:
For me using Strava live segments while routing and navigating on a Strava course that has segments embedded (course created before fw 6.2; connect app -> training -> courses -> purple flags / or shown in the point list on the edge) leads to crashing navigation when the a live segment triggers, such that the navigation needs to be restarted. This happens for > 80% of the segments.
Courses build on Strava lately (after upgrade to fw 6.2) do not have any segments embedded any more, so navigation does not crash, but no live-segments any more.
I tested a newly created Strava route today. On the map on the device itself, I could see the segments (green line with green/red square at start/end). But the live segment screen was not popping up, neither could I see the summary data screen, listing all active segments.
