Is there any way to control the routing options on the 530?
While, I don't normally don't need routing, I have done a few tests in order to try and see how it works.
After doing some tests, I am left with the following issues:
1. Routing to cycle paths. I want to disable all routing on to cycle paths. I am riding at an average of 35km/h and the paths often have a limit of 20km/h, and are not appropriate for the speed I travel at.
2. Routing to cycle paths results in a route that can be up to 20% longer than riding on the road. This is very annoying.
3. Routing to lower speed roads, at the cost of making ride longer.
All I really want this device to do is to route like I was in a car, but avoid freeways or other busier higher speed highways. I am not really sure how you would implement this, but they certainly figured out how to enable riding on cycle paths at all costs.
I would not mind if cycling paths are added in to route if it makes the route shorter, but for me it makes no sense to go to cycle paths if it will make the route longer.
