Elevation incorrect?
I just rode today using firmware 6.00.  Started at 9000ft and went up to 12000ft.  I think the altitude gain may be right on my unit but the altitude in Garmin Connect and Strava both show the altitude as flat at 6400 ft.
Weird.
  • I checked on the GPS itself and it had the same inaccurate elevation.
    I looked at the current elevation and it is 9400 ft so it is readibg correctly now, just not on my ride.
    Previous rides look ok for elevation.
    Same problem here.  Updated to 6.0 a few days ago and just got the strangest elevation readings for a ride.  Noticed the elevation number was off during the ride and the downloaded profile is completely wrong.
    It's currently reading the correct elevation for my current location.
    Is it firmware 6.0 or coincidence?
    Hello, I have the same issue in 6.20
    please, take a look at the following image: drive.google.com/.../view
    We pretty much did the same ride and I ended up with more than 1.000m less than my partner, this is happening in every single ride.
    Can you please provide a solution?
