Did my exercise this morning and the cadence always go over 200 RPM. Any thoughts ?
I'd guess it's either sensor outputting invalid info, or Edge processing good data incorrectly.
If you can reproduce this, would be great if you can log activity with two different devices (preferably different models or vendors) at the same time, to see if they both show the same value. If both have the rpm jump at the same time, then it would suggest cadence sensor outputs something wrong.
What type of cadence sensor are you using?
i am using cadence sensor 2.
what do you mean by stop recording mid ride ? so the problem is in the edge software not in the cadence sensor ?
