Add Power Save Timeout setting
Could Garmin please add a "Power Save Timeout" setting to Edge devices just like on Forerunner devices. Sometimes I turn on my Edge 530 but then have to wait around for a while before the ride starts. And then I find that the Edge has turned itself off to save power, so then I have to turn it on again, make sure the sensors are properly connected, search for the right course, etc. It's a hassle. I wish there was an optional setting to make it wait longer. I understand that would reduce battery life but I'm not concerned about that.
  • There is a setting in the edge just like the FR series. Disable this:  in a pinch if this is not enough just start your activity for 1 second and then pause it  screen will be fine then
    Using Auto Sleep
    You can use the Auto Sleep feature to automatically enter sleep mode after 5 minutes of inactivity. During sleep mode, the screen is turned off and the ANT‍+® sensors, Bluetooth®, and GPS are disabled.
    Wi‑Fi® continues to run while the device is asleep.
    1. Select Menu > Settings > Activity Profiles.
    2. Select a profile.
    3. Select Auto Features > Auto Sleep.
