Is there a specific type of logic the device uses when it is attempting to navigate you on to the course?
When you load a course it gives you the option to navigate to the start of the course, if you choose to do this, the device behaves as you would expect.
But if i choose not to do this, what exactly does the device do? What should it do?
What I want it to do is navigate with the shortest route to the closest point on the route, but it definitely does not do that.
It seems to be still trying to navigate to the start of the route. If I continue on against the instructions, the routing does seem fine once I manually navigate myself on to the course.
Aaron
