I am so fed up with the continuous sounds when using 'navigation'. If you are off course, it will beep every 5 seconds. For ages ! Sometimes you decide going off route and it's fine if the Garmin beeps now and then; in the beginning a bit more often. But after say 5 minutes or so, it should just reduce the frequency. It's so annoying !! Of course you can decide to cancel the navigation etc. Or disable the beeps, but then you loose all other beeps as well. I fully understand why people are moving to Wahoo. After the Edge 820, which had a disaster-touchscreen, this is again a deception. Why can't Garmin fix things which have been broken for years ?
