fw5.50 sensor drop fest indoor riding!
Hi, I updated my  530 to 5.50 fw from 5.10 and and then 1 freeze screen after start-up, 1 freeze at shutdown screen, and today in 1h:15min indoor riding there was 1min:30sec sensors drop section(stages left craft g3 powermeter and garmin speed g1 sensor). well at least heartrate chest strap was stable in the riding. and here the riding is https://connect.garmin.com/modern/activity/4979925325 .
I am going to back 5.10 till new problemless update.
  • not only indoor riding; today at my morning ride 3 mins. sensors dropped out again and while riding, I went to status page / sensors then disable,re-enable PM and sensors (pm and HR chest) came back!
    Here it is the ride https://connect.garmin.com/modern/activity/5041663056 at 01:05:50 - 01:08:40 drop section.
    I will install 5.51; I hope this problems will be over soon! @
  • Odd, I'll have to keep an eye out but I did a 1:15 indoor ride and didn't notice anything.  Detailed review shows my Quarq may have dropped for 1 second during the ride (this is 5.51)
    I had been on the 5.48 beta before that and never noticed anything specific, looking back on my most recent outdoor ride with 5.48 I can't see any obvious issues either (maybe I'm missing it since outdoor riding is a little more volatile).
    I use a Quarq, PowerTap G3 Hub, old GSC sensor, Varia Gen2 (outdoor), TickrX and Garmin HRM-TRI between setups for most of my ANT+ gear noted in recording I referenced (sorry, no stages to compare).  A standard out front mount for both bikes...
    I should have mentioned... I use ANT+ for all of my sensor connections.  Do you use all ANT or a combination?  Wonder if it plays some role at all.
  • Stages G3 105 5800 left crank and HRM-Run both connected with ANT
