5.50 not on Garmin Express
Just logged into GE and I don't see 5.50 on there. Any reason why??
  • Garmin Express does not report the build on the unit, but rather reports the latest build it has access to for that unit.
  • Thanks, Does that mean it will not reflect the change until it "officially" rolled out via GE or GC? I updated via the "sticky thread" link.
  • I sent a support request to Garmin about the issue and they confirm the same, here's the message from them - "Garmin Express may not see it (5.50) yet until its 100% rolled out, as long as the edge shows 5.50 in the menu > settings > system > about, you should be fine."
    I was having some sensor dropouts while running with the 5.10 firmware. I've done a short ride with the 5.50 firmware and saw no issues. I have a longer ride planned for tomorrow, so I'll see how that goes.
  • Garmin Express will show what builds your unique unit has access to. So depending on what group your unit is in with a phased roll-out will determine when build 5.50 shows up.
