Gradient map
Is it possible to switch off the gradient map that appears at the bottom of the map when navigating? I don't Realy need it and would rather have more map showing.
Cheers, Pete
  • Press the top right button to bring up the menu, scroll down and select Data Field, toggle Show Elevation Profile to off.
    When you return to the map screen, you'll need to scroll away from it, then back to it, before the change takes affect.
    There was a bug in previous s/w where this setting was lost every firmware update. It was fixed in 5.31
