Hi All
First time using this forum so apologies if this has been asked before, I did have a search and lots of topics on segments but I don't think anything covering this specifically. So ive come from the 520 where when you hit a segment it would pop up on your garmin with the map direction and time ahead/behind. This was great and exactly what I want (other than if you moved off this screen once the segment started then it was gone). On the 530 I can't seem to get this set up. The segment pop up screen comes up, you can personlise the fields so can add time ahead/behind and speed or power, great BUT it doesn't have the map part. What use is it chasing a segment if I don't have the map up. I see if I then navigate to the maps page I can see it on there, the kom time and the directions, but then I don't have the time ahead/behind which is quite key. So is there a way to get exactly what I want on the 530, or is it just a case of switching between the maps view and the segment view?
Map view
Segment view
