Poor track visibility, any advice?
Hi,
I wonder if I am doing something wrong, but depending on the kind of navigation I am doing, the track visibility seems very poor.
Note: I already put display brightness to 100%. Also I tried to set the map to "high contrast" mode. While these are small improvements, they don´t solve the issue
So what happens:
Case 1: Just navigation to a destination. E.g. being out and asking for the shortest way home.
-> Here I get the bright pink routing line. Very well visible, all good
Case 2: Loading a track on the device and following it without navigation.
-> Here I can chose the track color for "always display track". Depending on the color I chose the visibility is still good
Case 3: Actively following a track, but with turn guidance=off
-> Here I get the dark magenta routing line. Depending  on light conditions and map density, its more or less ok but worse then the upper cases
But what I usually want to do is
case 4: Actively following a track with turn guidance=on
-> now the dark magenta routing line AND the bright pink line are displayed above each other and mix themselves into a kind of black/brown.
Now with a bit of sunlight the track is barely differentiable from the other items on the map. With midday sunlight and glasses navigation is pretty useless
And the visibility becomes even worse if I enable the trailforks map overlay and with that ending up having all kind of colors on the display at the same time
So for case 4 I wonder if you experience the same. For me anything would be better, e.g. the pink line, the dark magenta line or also some other color. But not a mixture between dark magenta and pink with results in a very similar color as all other paths being on the map next to my route,
Any ideas?
