New Edge 530 Public Beta 5.44 Now Available
A new Beta software (5.44) for the Edge 530 has been released. Full change log, instructions, and software for installing the beta can be found Here.
  • For any issues that you encounter please fill out the form included in the download and attach it to an email to [email protected]. Please note that you may not get a response to the email unless we need more information on the issue you report.
  • Although this software is believed to be reliable, it has not yet been released for production and should be used at your own risk.
(Note: Please include a copy of your debugging folder in your response email if you experience any issues)
Change History
Changes made from version 5.34 to 5.44:
  • Added diagnostics to help track down an issue where the device can lock up.
Changes made from version 5.31 to 5.34:
  • Fixed an issue that caused bike radar disconnections.
Changes made from version 5.28 to 5.31:
  • Fixed an issue with sensors dropping out.
  • Fixed an issue where the device could become unresponsive.
  • Fixed an issue where ascent remaining was not properly calculated for segments embedded in a course.
  • Allow the elevation profile setting on the map to be maintained through future software updates.
Changes made from version 5.26 to 5.28:
  • Made stability improvements including a fix for a potential device freeze.
Changes made from version 5.25 to 5.26:
  • Added the ability to set target grade in the context menu for Indoor Trainer rides.
  • Fixed an issue where saved location names were drawn incorrectly on the map in night mode.
  • Fixed invalid Grit/Flow values appearing on the activity lap summary.
Changes made from version 5.24 to 5.25:
  • Fixed an issue with 12-speed gear shifting systems.
  • Fixed the Indoor Trainer 'Remind Me' prompt to ensure it does not prompt again if the user declines the reminder.
  • Changed the trainer resistance data field title to Grade for better clarity.
  • Modified the prompt for LiveTrack auto start timeout to occur at most once per activity.
  • Fixed an issue with ClimbPro where some short climbs were not detected.
  • Fixed an issue that caused POIs to show incorrect bearing and distance.
  • Only show Grit and Flow in the activity summary if they are valid.
  • Added letters to the Polish keyboard support Wi-Fi passwords that require non-Polish characters.
  • Fixed an issue that could keep the device from fully entering suspend mode.
