I have tried reinstalling the map via Garmin Express , however the error still exists on startup.
Any ideas on how to fix this ?
Thanks !
Thanks !
Same problem for me.
Managed to fix by going to navigation on the edge, while having garmin connect app open. The edge then gets you to authorise trailforks, this includes registering while connected to…
1. Install the Garmin Connect App on the phone
2. Connect your device with phone using Garmin Connect App (via Bluetooth)
3. Go to TrailForks app in Garmin Connect app (on your phone), create account and…
Thank you so much ..That worked ... .you are a genius !
I had logged the issue with Garmin and they had absolutely no clue... they are still investigating the issue !
Thanks again !
It works - Thank you
Registration on trailforks App is not immediate and the confirmation mail for signing in can take some hours, so be patient
Yes that worked for me too
> Authorizing Trailforks thru Garmin Connect mobile app (Edge 530 conectee)
> Unlocking Maps thru the Navigation menu on Edge 530
Many thanks!
I tried everything. Solved this issue by analysing the ".img" map files on the garmin drive. It turned out that the only file that did not update recently was creating the problem. On my device it's name was "D7557010A.img". Moved the file on the PC and after that it works how it should.
