Good day
I have a Garmin Edge 530 and I find it cannot record the minimum / maximum / average climb / average descent in%.
Even on connect IQ in applications or data fields is not a similar application (except hGradeMax), which, however, measured by GPS not according to the built-in barometer and therefore is almost unusable. According to the developer hGradeMax, data cannot be accessed from the built-in barometer!
Could this be remedied? (if it can do min / max / average temperature why could not% climb? eventually the data should be there just programmed). Alternatively, it would be enough if you could pull it out of the Garmin Connect program on your PC / mobile.
sorry for english this is a translator
