With 5.10 firmware can't connect to phone
Since the 5.10 firmware upgrade (which may or may not be a coincidence), my 530 won't connect to my phone any more. I tried deleting the pairing and re-pairing it but it wouldn't see it. Reboot of phone and 530 doesn't help.
Anyone else?
  • Did you remove the Phone from the Garmin device while also removing the Bluetooth connections on your phone?
    I've had issues connecting and pairing the Edge to my iPhone when I didn't remove the phone from the Edge and removed the BT connections from the phone... But, for me, my Connect IQ app stopped working, again unable to see my connected EDGE unit which is paired fine with Connect.
  • I had a similar issue, no way to pair the Edge to my phone.
    Deleting the Connect App and reinstalling it was the solution for me.
    0 Former Member over 5 years ago
    I didn't remove any connections before the problem appeared. The 530 was paired and working fine with my phone the last time I used it, and today it just didn't want to know.
    Removing and reinstalling the Garmin Connect app and then re-adding my 530 and re-pairing (I had deleted the pairing from the 530 when trying to troubleshoot) fixed it for me though - all working again. So thanks for the suggestion.
