Hi,
I am looking to upgrade to Sram Force etap group.
What control or specific display could I have on my Edge 530?
Thank you.
Hi,
Thank you.
You can see the available data fields under the gear category on the Edge,
I basically just use gear combo and gear battery
Hi aweatherall,
After your ride, you can you access a log of gear combo on Garmin Connect?
Thanks!
The ride summary shows the number of front and rear gear changes. Garmin Connect does not show all the gear changes, but the following site will if you wish to see time in each gear.
