Battery drain and varia light
Hi, I have two problem. The first is battery drain of 530 while the 530 is off and the other is that the 530 doesn't see the varia as light but only as radar. Someone have the same problem? Thank you
  • On the Varia issue:
    1. Delete your current pairing on the 530.
    2. Press and hold the power button on the Varia. It will initially flash blue, then after 2 seconds, it will flash purple. This shows it is in Pairing mode.
    3. On the 530, pair the Varia specifically as a Light (rather than Searching for All sensors).
    4. Press the power button on the Varia again to take it out of pairing mode.
    0 Former Member in reply to mcalista
    Thank you, that's works. Remaining only battery drain issue.
    does not work on current 530 version..just won’t pair period. Eventually the 530 just powers off while the icon is still spinning.
