Route navigation view partially covered by green bar
Can anyone explain how I can remove the green bar below? The green bar is was showing for the complete ride of 100+Km and the white circle moved back and forth. I navigate a route imported from Komoot. To my knowledge I have disabled climb pro (if this is what is showing) but is there any other setting I have missed?
  • It is a setting on the map page
    Go to the activity profile -> Data screens -> Map -> show elevation profile
  • This is the elevation profile. You can remove it by clicking the top right button then scrolling down to 'Data Fields' and then deactivate 'Show Elevation Profile'. I find it a bit useless as it just takes up screen space and is too compressed to show any meaningful information.
  • You also asked about the white circle, that is the location of your "Virtual Partner".  If you want to see the VP, it's location is also shown with a grey arrow head on the map page if the zoom level is such that it's location is on the amount of map you are seeing.  You can also enable the Virtual Partner screen if you want it.
  • Thanks for the help! I'm 99% sure I had disabled the "show elevation profile" in the profile..
