Navigation: How to trigger recalculation when the recalculation setting is set to off?
Hi,
Is there any possibility to trigger a recalculation of the route when the recalculation setting is switched to off?
Activity Profiles -> The profile you want to change -> Navigation -> Routing -> Recalculation (Prompted/Automatic/Off)
I do not want use the automatic or prompted recalculation. Especially the promped recalc is showing to many prompts and you have to press 2 buttons to skip them which is pretty annoying.
  • There's no current way of doing that (it would be a nice feature).
    It's possible that it might do something useful i(if you aren't too far) f you stop the navigation and restart it (don't select navigate to start).
  • Many thanks for your answer.
    You proposed solution might work but that is what I would like not to do....pressing many buttons during a ride.
    It woulld be great to have the recalculation easily accessible, e.g. with a long press of a button or in the menu when pressing the right top button.
  • You’d have to press a few buttons anyway.
    It’s a good idea and wouldn’t be that hard to implement.
    But it isn’t likely that you will ever see it.
