OSM maps - usage is broken in 4.10
Loaded 4.10 last night and went for a 60km ride today - it was a crap shoo (that means it was doggy poopoo). Good thing i was riding alone - otherwise it'll be embarrassing - why? cause i spent so much on a piece of junk. I noticed 530's Time to Destination data was doubled - my speed was not slower than 20km/hr.....distance to destination was approx 17km....yet it informs me it's gonna take me 2 hours and 6 minutes to arrive. I stopped and played checked my settings - in the end I think it was the OSM maps. v4.10 does not play well with OSM maps. I had 2 versions of OSM maps - the lite version and the routable normal one - and both had the same issue. Tthe TBT screen would get stuck, it will continually go from one navigation arrow to another navigation arrow,........on and on without ceasing - so i abandoned the OSM maps and went back to the Garmin cycle maps. Lucky that worked all right. Pro Tip - make sure u enable DEM world wide map also. Leaving it disbaled will mess with the garmin.
So don't use OSM maps with V4.10. I tried again later with different settings and again found the same issues - TBT screen would get stuck with OSM maps.
    Anyone else OSM broken?
  • I'm using OpenFietsMap (Benelux) which is based on OSM and so far i have no problems with it using v4.10 + navigation. Using Komoot for route planning (also uses OSM) and the navigation arrows are all on point.
    0 Former Member in reply to Rouleur
    Update: think i found my answer - I was on the Gravel profile. For testing I've switched to the Road cycling profile and using OSM maps the Time to Destination is now correct. There is something in the gravel profile that doubles the TIme to Destination......???
    but the TBT page is still stuck - it just stays at one arrow to the next arrow and i can't change to another screen......I had to reset it to be able to gain control back.
