Problems syncing segments to Edge 530?
Hello,
Is it just me or does anyone else have a problem syncing segments to edge 530 for live segments feature? I use method when I star a segment on strava and then I make sure I can see it on the list in garmin connect. Segments always DOES appear there. Then the problems starts to occur. Sometimes segments sync only via Garmin connect through paired smartphone, sometimes that doesn't work so I have to use garmin express. Sometimes it adds some segments and some don't. And it doesn't matter whether the gradient of the segment is positive or negative! Last time nothing worked so I had to de-select strava segments for garmin segments in dashboard page on garmin connect, then select it back on, to remove all segments from 530 and then make sync all segments once again. Again it didn't get one segment back through garmin connect but all of them through garmin express.
I'm frustrated with this, which is supposed to be an easy process. Can anyone explain to me what might I be doing wrong or how this syncing process works? Is there a different way live segments and adding segments would work? Does adding .fit files with segments data work in live segments when I add them manually to device folders?
Thanks for responses.
