NP & Avg Power Issue indoor training
Hello
yesterday i tried using my edge 530 for indoor training combined with Trainingpeaks...
Normalize power and average power number were completly crazy ....
any one the same issue ? i've had that issue with my fenix 5+ in the past, a correction was made...
sK
  • I'm guessing the values on the Edge are correct, but what you are seeing in Garmin Connect was wrong?
    There was a bug in GC that was changing the numbers, which got fixed, but it sounds like it might be back.
    Could you post the FIT file or a link to it?
  • Nope, the number i saw were not correct so i quit recording it on garmin.... used wahoo Slight smile
    the current power and avg 3 was correct.... but for an unknown reason, avg power and NP was not....
  • Do you have the FIT file from the Edge for that activity?
    What build are you using on the Edge?
    The F5+ and I believe the Wahoo have a power spike filter that strip out out obviously bad values from a power meter.
    What power meter are you using?
    The 530 added that in build 3.55.
