Incorrect Sync for Workouts from Training Peaks
Hi,
I create a workout in Training Peaks, with several blocks that are repeated.
The Workout is synced to the 530, but somehow it is not correct. Today, I wanted to do 3x 6min hard + 6min slow. After the first 12 minutes, I was suddenly in cool-down, because (as I found out later), the Garmin synced only 1 repetition instead of 3 (double-checked Training Peaks again, there are 3 of them).
On another occasion, it just jumped one intervall (setting a lap with 0 seconds). As you might imagine, that's pretty unfortunate in a planned workout. Please have a look into the syncing process, I believe there is some work to do..
Another note: When I complete a workout, in Garmin Connect there are two entries: 1) the workout 2) the ride. Would make sense to show only one item when the ride covered the workout (as it is implemented in Training Peaks).
Regards,
Steve
