With the new 3.50 version update, following statement can be read:
We recommend using the ANT+ connection on a sensor with your Garmin devices. There are no customer facing benefits to using the BLE connection unless that is the only option for the sensor to be used and there are often additional features to be gained by using ANT+ with a Garmin device. We see the main customer benefit of a BLE connection on a sensor to be for usage with indoor training apps running on smartphones, tablets, or home desktops at this time.
In my opinion that statement sounds as an excusation. Ther may be different reasons for the user to use BLE sensors, and if you sell the device as BLE compatible, you must fix the issues and offer a proper user experience. If other vendors can do it, you also should.
I sincerely hope that sensor issues are fixed in this release.
