Hi. When on a live segment if if switch from the segment screen to elevation the chart always shows a steeply climbing brown hill what is it indicating please? At the segment end it goes back to the normal green elevation chart.
There is a bug in the current release when executing a segment that is embedded in a course file (a course loaded via the Strava Route app) were it does not show the correct elevation profile. This I've been told is fixed in the next full release. There will also be a change to support segments and ClimbPro climbs concurrently,
On the elevation page ClimbPro color codes climbs from Cat 4 through to HC.
The color you are seeing is likely dark red, which is for HC climbs.
Could you post the course file?
file would not upload try this link: https://drive.google.com/file/d/1dyQGj08yDOhvwlsHy1DNG3p0ANTYsLdS/view?usp=sharing
