A new Beta software for the Edge 530 has been released. Full change log, instructions, and software for installing the beta can be found here.
- If you experience sensor or phone connectivity issues with this build, our engineering team would like to hear about your experience so they can work toward resolving any remaining issues. Please visit the Garmin forum for the Edge 530. Please note that you may not get a response to the forum post unless we need more information on the issue you report.
- Although this software is believed to be reliable, it has not yet been released for production and should be used at your own risk.
Change History
Changes made from version 3.20 to 3.41:
- Fixed a connectivity issue that could cause ANT+ or BLE sensors to lose connection and never reconnect.
- Fixed an issue with Bluetooth communication that was impacting phone connectivity and device power down stability.
- Fixed a shutdown that could occur when calculating a route.
- Updated the sensor pairing user interface to encourage pairing over ANT+.
Changes made from version 3.20 to 3.33:
- Fixes connectivity issues that could have caused ANT+ or BLE sensors to lose connection and never reconnect.
- Fixes an issue that caused Bluetooth communication to lock up, which could have affected phone connectivity and device power down.
- Improved performance in GPS + GALILEO mode.
Installation Instructions
- Connect your Edge 530 device to your computer using the micro-USB cable.
- Download and unzip Edge530_341Beta.zip and place the GUPDATE.gcd file in the \Garmin folder of your device's internal storage drive.
- Disconnect your device from the computer, approve the update on the Edge, and wait for the update to finish.
- If you would like to revert to the last public release software, follow the above steps but place the GUPDATE-320.GCD file in the \Garmin folder. Rename the file to GUPDATE.GCD before disconnecting your device.
NOTE: If you revert to an older version of software, all of your settings will be reset to defaults.
