Is there a bug with the notifications view?
I received a multi page text whilst riding but it was impossible to read the first half as the Edge repeatable scrolled to the bottom.
If you press the up key, it scrolls up, but then immediately scrolls down again.
You can witness the same when trying to view the power profile.
Menu -> My Stats -> Power Curve -> One Month
I can't see the graph as it scrolls to the bottom of the text. Again if you press up you can briefly see the graph until the edge automatically scrolls down again.
Forgot to add, I'm on Beta Firmware 3.33 (but as per below it sounds like its on 3.20 as well).
Is there a reliable way to report bugs to Garmin? If you ring support then just try and get you to reset the device etc........
Regards, Dave.
