Ok, any help will be gratefully received.
My friend created a route the other day with RWGPS. Did the usual, pinned it, made it an active activity in Dynamic watch web and then downloaded to the the 530. This worked perfectly but then when I started the course, what a nightmare. Literally, every 2 minutes the screen flashed up with an obvious course direction. Additionally, because I have audio prompts on ( which is excellent normally) I was announced with the word "dot". In an attempt to reduce this problem, I turned the Nivigation prompts to text only . Unfortunately, this populated the bottom with a black banner every 2 minutes (but at least I could just see the map) the "dot" announcement continued.
Got to the cafe stop, paused and turned off. When I turned the the 530 back on, I was met with course can only create so many points? But then, when I started the black banner now contained course changes (which is what I expected from the start). I turned off the audio prompts.
I should have checked the course, because he had basically put hundreds of course dots on the route. I blame the fact he hasn't done a course before. But unsure to why, it caused this much of an interference in the routing?
I started using RWGPS when I had a Bolt and required cue cards. But I've never had any problem like this before.
Any advice to what to set the 530 to? If the route has cue cards, do I turn turn guidance and off course warnings off?
Any ideas what "course points" and "always display" mean?
Thanks
