Hi. If I have added and enabled an open street maps img of my region as well as the standard europe which map will the 530 use. Do you have to disable other maps of the same region to use the OSMap? Thanks
You only want one map of the region you are in active so if the area you added is covered by the Garmin Europe map disable the Garmin Europe map.
