I upgraded from Edge 520 to Edge 530 and the vibration alerts on my Varia Vision ceased.
How can I re-enable vibration alerts?
Here is my setup:
Edge 530 Firmware 3.20
Varia RTL 510 Firmware 3.50
Varia Vision Firmware 3.60
Here is my setup:
I tried it and the Vision (HMD) vibrated for me.
Try putting the RTL510 in test mode and see if you get the vibration from the Vision. With the RTL510 off, hold the power button down until the indicator LED goes blue, purple and then green. When it gets to green let go.
You can run the test with just the Vision and the RTL510 and also with the 530.
That seems to have reset the vibration alerts. Thanks!
