Do you know where can be problem with pairing sensors via ANT+? I have three powermeters Quarq, Stages left only and Stages LR. I can connect these PM only via BLE, but after while they are disconnected, so I want to use them via ANT+, but edge can not find them via ANT+ protocol. Also have problem with find Shimano Di2 wireless unit via ANT+. In edge 520 and Fenix 5 it works smoothly. If I wanted to pair Speed and HR sensor via ANT+, then I had to place sensor 20cm from Edge 530, but after pairing they work. Is this a known problem?
