The Edge 130+ has Climb Pro, as advertised, but it appears that this hardware is missing the menu to change the default climb score.
I frequently come across these directions:
"The ClimbPro feature analyzes the course and identifies climbs based on the following criteria:
A climb must be a minimum of 500 meters in length.
The average gradient must be a minimum of 3%.
The climb distance (in meters) multiplied by the average gradient (%) must:
Be greater than 1500 if climb detection is set to Show All Climbs.
Be greater than 3500 if climb detection is set to Medium-Large Climbs (default setting).
Be greater than 8000 if climb detection is set to Only Large Climbs."
But there is no 'Activity Profiles' menu nor is there a 'Climb Detection' menu on this device. I want to change this value to 'Show All Climbs'.
Thank you.
