Garmin 130 plus jump (airtime - hangtime)
I have a Garmin 130 plus. I think after the latest update ... he isn't recording my jumps. "hangtime" "airtime" Someone a solution to fix this or with the same problem? What to do to fix this?
  • Maybe it's because you don't jump high enough :-)
    Jokes aside, I'm running the latest firmware and have no problems with the 130 recording jumps. Make sure you're starting the ride as "Mountain", as I believe metrics like Grit, Flow and Jumps are only available in that mode. If you're already doing that, then try a factory reset and see if that helps.
