bug: Elite Tuo trainer - speed incorrect
Running version 2.80 on Edge 130+
Elite Tuo trainer (firmware 194) connected via ANT+ FE-C
Symptom: speed is exactly half what is displayed in Elite myEtraining app.
Workaround: change the default Trainer wheel size from default 2096mm to 1048mm.
Comments:
1. The same trainer when used with an Edge 530 (firmware 8.20) works correctly on default settings (ie no configuration changes required)
2. An educated guess as to the cause of this is that the Elite Tuo 30mm diameter roller has 2 magnets and thus there are two speed pulses for each roller rotation
