Hello,
I want a simultanious video start and stop with my 1050 livetrack start if the virb is paired with the 1050 and activated. Like it has worked with my edge 1030
Yes, I now can start and stop via virb widget of the 1050 a virb record (you have to activate the virb widget for one time to activate this function of the 1050).
But I want both ->Livetrack start = automatic virb start.
Ad the 1050 virb sensor config -> virb start/stop record with Livetrack selection -> with no function -> Bugreport
My livetrack is starting at my 1050 and no red light = no record at my virb.
KI said it should work doing the following:
Thanks for your help
Erik
Setting Up Simultaneous Start
- Pair the VIRB with Edge 1050:
- Turn on your VIRB camera and ensure it is in remote control mode.
- On your Edge 1050, go to Sensors > Add Sensor > Search for ANT+ devices to find and pair the VIRB.
- Configure Automatic Recording:
- Select the paired VIRB camera from the sensor list on the Edge 1050.
- Go to Sensor Details > Recording Mode and set it to "Timer Start and Stop".
- Configure LiveTrack:
- Open the Garmin Connect app on your phone.
- Go to Safety & Tracking > LiveTrack.
- Enable Auto Start to start a LiveTrack session automatically whenever you start an activity.
How to Use
- When you press the Start button on your Edge 1050 to begin your ride, the device will now:
- Activate the LiveTrack session via your phone.
- Send a signal to the VIRB to start recording video simultaneously.
- When you stop the ride timer, the VIRB will automatically stop recording.
Requirements
- Edge 1050 must be paired with your smartphone via Bluetooth, and the Garmin Connect app must be running.
- VIRB must be within range (ANT+ connectivity).
- LiveTrack must be set up in the Garmin Connect app prior to the ride
