Edge 1050 doesn't adjust resistance on tacx neo 2T trainer to maintain power level when following a workout.
The trainer is paired with ANT+
I start the workout from the edge
The edge says I'm in power mode (i.e. ERG)
Trainer doesn't adjust resistance to keep me at the power level prescribed in the step.
The internet says it should be able to do this.
  • I could find that the neo 2t power can be only adjusted via bluetooth.
    I didn't tried yet to adjust power with the edge 1050 but using Zwift it worked perfectly (using Bluetooth).
    Try to go to sensor settings and use the smart trainer with bluetooth instead of ANT+
  • the 2T can be controllable via ANT+ (FE-C) or BT (FTMS) also, but the 1050 is able to do it only via ANT+, it has no FTMS support as i know.
      what kind of leds are on on the 2T ? the red for sure , because you plug it into the socket, but the yellow? (the blue is for BT ) ?
    are you paired it in the indoor trainer menu as smart trainer? and not in the sensor menu as power source and etc , right?
